Showerhead Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2011, 09:41 AM   #1
Showerhead replacement
Trying to change out showerheads....Amidoinitright?
You see what I have to deal with, so tell me if I need something more or if I have what I need/what I need to do.
THANKS!
BoxAlarm is offline   Reply With Quote
Old 06-28-2011, 09:49 AM   #2
Too Short? Cut it Again!
Should work. Just do not over tighten things.
Old 06-28-2011, 10:18 AM   #3
So torque out the old one, screw in the new one? It's as easy as that?
Old 06-28-2011, 10:39 AM   #4
If you need excessive force to get this shower assembly out you could have a problem. I doubt you will though.
Do wipe out the threads of the fittings for sure if you can reach them.
As you fit the neck into the wall, go slow to make sure you engage the threads properly. You don't want to cross thread that hidden connection or you will have to pull the wall apart to fix it.
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
Leaky showerhead after valve replacement mr.perplexed Plumbing 3 01-30-2010 04:05 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
