#1 |
Showerhead question
I just bought a new showerhead, old one was ugly, wouldn't rotate, etc...
Anyways, the one I bought is one of those 7" "rainshower" types. Looks great, but the water pressure just isn't there like it was with the old one. I believe the reason the old one had the pressure is because it was only 3 holes, with the "massage" feature. The new one is probably 40-50 holes. So my question is, is there a way to keep this head and add pressure to it, or is the pressure dependent on the showerhead design? Thanks in advance |
#2 |
Journeyman Plumber
Showerhead question
Look inside the new head, where it would screw onto the shower arm, is there a flow restrictor in it? If so remove it.
Fix it right the first time, so you won't have to fix it a 2nd time. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Showerhead question
what does a flow restrictor look like? I guess I'll take it down and inspect tonight. thanks.
| Display Modes | |
| subpanel question | Brik | Electrical | 2 | 11-30-2008 06:31 AM |
| Basement Renovation Question | KUIPORNG | Remodeling | 234 | 08-26-2008 09:19 AM |
| General easy drywall question | bigboyjoel | Building & Construction | 3 | 05-27-2007 09:52 AM |
| Site work question | Jonny Homefixer | Building & Construction | 6 | 11-02-2006 09:43 AM |
