Showerhead Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2013, 02:12 AM   #1
showerhead pressure
my showerhead gave good pressure, all of a sudden the pressue became low, i unscrewed the half of the showehead off, that little round black ball thing connected th shower faucet still gives good pressure, but when i screw the showerhead other half on the water pressure decreases. why? thanks happy new year
phillybadboy is offline   Reply With Quote
Old 01-03-2013, 07:26 AM   #2
DIY staff
Rewards Points: 7,174
There is usually a filter screen/flow restrictor where the head screws onto the shower arm--remove and clean that.
Soaking the head in vinegar might loosen up any lime build up---
Old 01-03-2013, 01:09 PM   #3
thanks mike, when i unscrew the cap of my kitchen sink faucet i see a screen, but i don't know where the screen is for my showerhead
Old 01-03-2013, 02:11 PM   #4
i have a plastic pivot ball, the water coming out the ball to me seems like it has good pressure,i do see a o-ring between the pivot ball and nozzzle. does some showerheads not have a screen at all? and the arangements i know comes like this plastic ball,screen,nozzle.can it come in this arrangement screen,pivot ball,nozzle? can nozzle by itself cause a problem, i used a toothbrush to clean,seems clean,should i soak the nozzle in somekind of liquid?
Old 01-03-2013, 02:29 PM   #5
DIY staff
The filter/restrictor is where the shower head is attached to the shower arm---
A soft brush could help free up the lime----find that restrictor--I bet that's where the crud is---
Old 01-03-2013, 06:16 PM   #6
if not, could it be the holes in the nozzle? i did clean with toothbrush, looks clean, maybe i ned to soak in vinegar, any vinegar would do?
Old 01-03-2013, 07:11 PM   #7
Rewards Points: 558
You can soak the head in CLR which will clean the holes in the nozzle and any crud…
epson is offline   Reply With Quote
Old 01-08-2013, 06:57 PM   #8
i soaked in vinegar, seemed to remove build up, but pressure still low, i think the problem is a dirty screen, i haven't found the screen yet, i think it may be located inside the plastic pivot ball
Old 01-08-2013, 07:03 PM   #9
Roofmaster
Rewards Points: 2,172
Ive used that CLR and it did nothing to remove rust stains or clear a clogged shower head. Whats the secret?
Old 01-08-2013, 08:32 PM   #10
Rewards Points: 243
Don't dilute it, use full strength. Just don't count on there being any chrome left when you are done.
chemman is offline   Reply With Quote
Old 01-08-2013, 08:43 PM   #11
Rewards Points: 558
Your supposed to soak the shower head in it.
Old 01-09-2013, 02:22 AM   #12
747
registered
747's Avatar
Rewards Points: 534
I use CLR also. Just don't dilute it. Or just a little. Shower head take it apart.
747 is offline   Reply With Quote
Valve sizing: choosing the differential pressure Nanimo Plumbing 0 06-20-2012 09:42 PM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 05:57 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
