Shower Won't Shut Off! - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-29-2011, 12:06 AM   #1
Angry
Shower won't shut off!
So hubby and I are replacing what was a tiny neo angle shower with a tub sized shower at our cabin (which is a 4 hr drive away... this is important). We gutted the old shower, purchased a basic Delta valve/faucet and proceeded to re-plumb! With the new rough in in place, we tiled over the plumbing, proceeded to install the balance of the new plumbing (cartridge, bonnet, etc). In the process of installing this I was fiddling with the cartridge to change the hot water limit stop location, and promptly dropped it on the tile floor! Needless to say the cartridge blew apart, springs and rubber washers flying everywhere! Fine... laugh!
I consulted the internet on how to put the pieces back together (after a big freak out by the hubby!). I'm fairly certain I put all the pieces back where they belonged, but after we installed the cartridge, handle, etc, and turned on the shower, it ran ok... but the water wouldn't shut off! Not even a little... NOT AT ALL!
Needless to say we pulled the cartridge out, turned the water off at the shut off set screws. Now that I'm back in town I sheepishly made a trip to the plumbing wholesaler and purchased a new cartridge. Hoping to get back next weekend and try my luck as a plumber again.
But until then........ my question to the plumbers here is... Is it the cartridge that is the problem? Or could there be some underlying other issue, like could something have gone REALLY WRONG in the rough in that will only be able to be fixed if we pull all the tile off the wall and start over??
Any/all advice is more than welcome. Thanks!
shadesofblonde is offline   Reply With Quote
Old 04-29-2011, 12:48 AM   #2
Too Short? Cut it Again!
Kind of confused but if the only thing between the water supply and the shower head is the valve and cartridge doesn't it have to be a flaw there? Or are you saying it is leaking water between the shower valve and the cutoffs?
I am guessing the replacement cartridge will fix this. Those things tend to crack in strange and mysterious places when dropped. I would never have taken the time to even try to rebuild one. And I am not a plumber! I just pay them handsomely and have put many of their kids through school over the years.
I just cannot stand the arrogant souls storming into my home (I don't mind them in those of my clients) lecturing me about faucet repairs I attempted myself and managed to "f" up. And of course I don't even have to pay them--much--for work on my place.
Old 04-29-2011, 05:16 AM   #3
Hey shadesofblonde. I'm a little confused by your posting as well. You said that once you had the handle and everything installed you turned the water on at the valve, but couldn't get it to shut off. Is that right? Or once you had all the valve components installed you turned the water on at the meter and couldn't get it to stop?
Rick
http://myhandyadvice.blogspot.com/
sharpsport is offline   Reply With Quote
Old 04-29-2011, 06:43 AM   #4
DIY staff
Rewards Points: 7,174
Shades of Blonde----Delta has a very good technical help line---They will walk you right through that job if you can time the install so they are open.----Mike---
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Where the heck is the shower shut off valve? Monika2024 Plumbing 7 12-17-2009 02:19 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Shower Dripping Hot Water, Should I Shut Off Emergency Oil Burner Switch? bman46 HVAC 1 10-02-2007 02:04 PM
