Shower Water Pressure Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-19-2013, 10:49 AM   #16
Your spout has a simple valve inside. When you pull up on the plunger on the spout, it shuts off the water that would normally come out of the spout.
Now, the water has no place to go except up the pipe to your showerhead. And when you turn off the water, the reason water keeps coming out of the spout for a little bit is that it's draining the water in the pipe that runs up to the showerhead.
Your valve in the spout is shot. The spout screws on....and unscrews off. Simply unscrew the existing one, take it with you to the store, and buy a new one, ensuring the pipe thread size is the same. Most are 1/2 inch NPT.
Screw on the new one using Teflon tape wrapped on the threads...wrapping in a clockwise manner so the tape doesn't try to come off as you're tightening it.
Then take a shower.
RoyalAcresRod is offline   Reply With Quote
Old 08-19-2013, 03:57 PM   #17
Rewards Points: 175
will do, save myself a few bucks ... just need it to work while we renovate our other bathroom!
Thanks.
vivithemage is offline   Reply With Quote
Low hot water pressure in upstairs sink but not upstairs shower amn70 Plumbing 1 05-12-2011 10:34 PM
Water Pressure in shower realniceguy5000 Plumbing 3 02-06-2011 09:52 PM
water pressure in shower issues sflamedic Plumbing 8 04-07-2009 01:55 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 05:27 AM
No Hot Water Pressure In Shower Randy Stuempfig Plumbing 6 01-02-2008 07:35 PM
