Shower Water Pressure Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2013, 10:18 PM   #1
Rewards Points: 175
Question
Shower water pressure question
We have a basement shower very similar to this:
For some reason, when you pull on the little plunger to get the water to spray out of the top, the water pressure is horrific, and the faucet leaks a fair bit of water still.
I was wondering what you guys might think of starting with this? My plumbing skills are weak, but I do know where to shut it all off to start ripping it apart and working on it.
I just want to get the shower usable, as this is our second full bath and is in an area we rarely ever go in the house so not a huge deal, but i'd like to use it while we renovate our main bathroom. So gotta get this one up to snuff for now!
vivithemage is offline   Reply With Quote
Old 08-13-2013, 10:29 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 924
You can buy water saving shower heads that reduce the "pressure" from the head.
They have flow restriction built into them to reduce water consumption. Consequently- the flow pressure is weakened.
For the tub spout, you can buy replacement spouts- pretty easy to change out.
Just make sure you buy one made for the type of pipe you have(copper, galvanized iron)
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (08-18-2013)
Old 08-13-2013, 11:25 PM   #3
Rewards Points: 14,312
Anytime your doing plumbing work trash is going to get knocked loose in the pipes.
Remove the shower head and turn on the water, plenty of flow then the shower head is plugged up.
Still not working then there's trash in the anti scald valve and the control valve needs to come apart and be cleaned
Old 08-14-2013, 10:08 AM   #4
Rewards Points: 175
I actually did that Joe, it was pretty weak ... which makes me think it is the faucet.
How do you remove the faucet exactly?
Like I said, when you pull the plug on the faucet, it blocks only a bit of water to send to the shower head....so I am guessing it is just crap.
Old 08-14-2013, 11:53 AM   #5
Rewards Points: 44
Are you saying when you pull up on the lever at the end of the tub spout a lot of water still comes out of the spout? If yes, you need to replace the tub spout. The diverter inside is shot.
Dan
djlandkpl is offline   Reply With Quote
Old 08-14-2013, 01:36 PM   #6
Rewards Points: 175
Is that pretty difficult? I guess I could just youtube how to do it!
Old 08-14-2013, 01:40 PM   #7
Rewards Points: 736
They screw on. It's really simple.
http://www.familyhandyman.com/plumbi...spout/view-all
TheBobmanNH is offline   Reply With Quote
Old 08-14-2013, 01:43 PM   #8
Rewards Points: 175
that link didn't work
Old 08-14-2013, 02:09 PM   #9
Rewards Points: 736
Works for me, but just google "replace bathtub spout" and you'll find about 100 links. I linked to the Family Handyman article, about fifth down in the list on Google
Old 08-18-2013, 07:42 PM   #10
Rewards Points: 175
Took it off, she's old!
Since the plumbing exists, can I just get this:
http://www.amazon.com/Pfister-R89-8G...=shower+faucet
or do I need to get new plumbing/valves or something?
Old 08-18-2013, 09:00 PM   #11
Plumber
Rewards Points: 924
shower heads are interchangeable, but the rest needs to match the model of the existing valve.
Old 08-18-2013, 09:59 PM   #12
Rewards Points: 44
You can get just the tub spout. It may not match the rest of the fixtures.
Dan
Old 08-18-2013, 10:23 PM   #13
Rewards Points: 175
I'd like to just get that kit then ... does that mean a need the new valve? Is this valve interchangeable with anything out there currently?
Old 08-18-2013, 10:43 PM   #14
Plumber
Rewards Points: 924
Have you pulled the cartridge from the valve body to see if it is clogged?
You need to confirm that the trim kit you linked to will match the valve mounted in the wall. New styles come along that don't always work on older valves.
I suggest any after market shower head and arm will work- same for the tub spout except you need one that matches the type of pipe stubbed out of the valve such as copper or iron pipe thread.
The trim plate will be the uncertain part. I don't know if all PF trim interchanges with the rough in valves
Old 08-19-2013, 10:24 AM   #15
Rewards Points: 175
Maybe I should step back, is the valve the one actually sending water back up the shower head?
If so, could it be the one causing the faucet to leak a bunch of water when engaged?
If so, it sounds like I might be wise to replace the valve.
I can't really look at the valve, because it's all soldered together. I can view it from the back side wall, as it's open and in a laundry room so it is accessible as it currently sits.
Low hot water pressure in upstairs sink but not upstairs shower amn70 Plumbing 1 05-12-2011 10:34 PM
Water Pressure in shower realniceguy5000 Plumbing 3 02-06-2011 09:52 PM
water pressure in shower issues sflamedic Plumbing 8 04-07-2009 01:55 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 05:27 AM
No Hot Water Pressure In Shower Randy Stuempfig Plumbing 6 01-02-2008 07:35 PM
