Shower Water Are Just Warm... - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2013, 09:46 AM   #16
Great! tnx!!
lulu1212 is offline   Reply With Quote
Old 03-19-2013, 02:22 PM   #17
I think you just need to take off the access panel from the front of your water heater and turn up the temperature so it's hotter. For Energy Star a lot of them ship with a lower then optimal temp so that they save energy. I turned mine up to 180F I think. You just use a tiny screw driver and just turn it up little bits at a time till it's as hot as you want. Give it at least an hour before testing, and keep in mind if you have kids you don't want it SUPER hot. I'll most likely turn mine down once I have kids.
gotnospice is offline   Reply With Quote
Old 03-19-2013, 02:37 PM   #18
No kids yet
About the water heater...you think this is a good idea? mine i think runs on gas and its easy to adjust...but i keep hear people say DONT change to temp on the water heater for some reason...
Old 03-19-2013, 02:40 PM   #19
Rewards Points: 44
Originally Posted by lulu1212 View Post
No kids yet
Don't do it.
If you have hot water everywhere else but the shower, the problem is with the valve or the valve settings.
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
lulu1212 (03-19-2013)
Old 03-19-2013, 02:42 PM   #20
Well if your sink is fine then it's probably just the length of your showers vs the size of the water tank. But if your sink/kitchen temp doesn't feel hot enough then I would also adjust the temp on the water heater.
The Following User Says Thank You to gotnospice For This Useful Post:
Old 03-19-2013, 03:07 PM   #21
everywhere else in the house water are extremely hot. even in the sink right next to the shower...
Old 03-19-2013, 03:09 PM   #22
When you first start the shower is it really hot?
Old 03-19-2013, 03:14 PM   #23
No. Its cold for about a minute then it gets warmer...
another strange thing i noticed is that in the morning the water are even colder...like you cant even try to take a shower...and for some reason during the evening its "manageable" to take a shower
Old 03-19-2013, 03:16 PM   #24
Well that's normal for it to be cold when you first turn it on. You have to imagine the water leaving the tank and traveling all the way to the shower head. That entire distance is cold water that's been sitting in the pipes. This is also why it would be colder in the AM.
But after a min or two is the water hot?
Old 03-19-2013, 03:24 PM   #25
in the AM no....i can let it run for 5 min and get nothing...
Old 03-19-2013, 03:26 PM   #26
And is the pressure good? ie lots of water comes out? Is it a tub too? Have you tried letting it warm from the tub faucet before activating the shower?
Old 03-19-2013, 03:28 PM   #27
Yeah I did try the lower faucet... Same thing.
About the pressure its constant always... And it's just Ok... I wish it was better
Old 03-19-2013, 03:34 PM   #28
Rewards Points: 44
Can you post a picture of the valve in the shower and also one of your hot water heater? If you can't post pictures, what is the brand name on the valve and hot water heater?
Old 03-19-2013, 03:46 PM   #29
ill post it as soon as ill get home. tnx!
Old 03-19-2013, 04:33 PM   #30
Water Heater is Rheem and faucet is Glacier bay
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Only warm water in shower - Pfister pvstansel Plumbing 1 09-25-2011 12:42 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
