Shower Waste Pipe To Toilet Waste - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2011, 05:07 PM   #1
Shower waste pipe to toilet waste
I have had a wet room recently installed due to disability but the plumber,
Linked the shower waste to the toilet waste.
On asking around I have learnt that a P-TRAP should be used to stop any smell from the toilet waste entering the shower drain.
Here is the details of the drain fitted.
Is this a P-TRAP And is this the correct fitting for this job thankyou..
50mm water seal trapped gully for use with a floor former.
Unique 2 part gully for simplified installation.
Suitable for use with flexible sheet flooring.
Top access gully has a removable inner cup for easy cleaning.
Flow rate in excess of 40 litres per minute.
2" horizontal outlet to BS5255 with 2" x 11/2" solvent weld socket reducer.
Simple to install.
Utilise with a stainless steel adaptor if laying a tiled floor or to complement modern tastes
microbar is offline   Reply With Quote
Old 05-17-2011, 05:20 PM   #2
Rewards Points: 262
Reply moved to original thread which asks the same question.
Jim F is offline   Reply With Quote
Old 05-17-2011, 05:24 PM   #3
Originally Posted by Jim F View Post
Your p-trap would have to be somewhere downstream from that horizontal outlet pipe and would be considered a running p-trap. Is this shower adjacent to a bath tub? If so, it may share the tub trap. If it connects directly to the toilet waste pipe without a trap, it will allow sewage gas up through the shower drain.
Thanks for your reply
I have had the bath tub taken out and a wet room installed.
the shower waste is now Linked to the toilet waste.
I dont think he has installed a running p-trap in the horizontal outlet pipe.
Waste from other toilet? scottl31 Plumbing 22 11-18-2010 03:38 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 01:10 PM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-22-2010 12:45 AM
Pipe knocking when toilet flushed guykovera Plumbing 5 09-27-2008 09:17 PM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 01:07 PM
