Shower Valve Stem Repair Challenge - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2013, 08:03 PM   #1
shower valve stem repair challenge
I am attempting to replace the valve stem/seats for a Kohler 3 faucet tub/shower. The outer covering over the cold faucet stem is stuck. In the old stem that is getting replaced, this cover is metal.(The new ones are plastic as seen on the hot faucet stem already replaced) I have tapped it with a hammer repeatedly, used a vice grip-which is just tearing apart the metal, i've tried heating it with a torch...it's not budging, just tearing off metal pieces.
Any suggestions would be greatly appreciated
turbo91 is offline   Reply With Quote
Old 08-25-2013, 09:13 PM   #2
Rewards Points: 42
Dan
djlandkpl is online now   Reply With Quote
Old 08-25-2013, 09:49 PM   #3
A plumbing socket wrench doesn't get a grip on the valve nut. On the hot water stem, that I already fixed, I had to use a deep socket which still meant hacking off part of the valve stem to reach it.
Old 08-25-2013, 10:16 PM   #4
Rewards Points: 320
Is there a little horseshoe retaining clip that's still in there by any chance?
Try soaking stem nut in penetrating oil like liquid wrench or pb blaster overnight. It looks like you got that stem nut worned down to a nub, doubt if you can get a socket over it now.
You may have to dremmel or cut it out like you did the hot water one. Some can be a real pain to get out. Anyway you could just cut off stem nut without destroying tile or valve stem so you can get a deep well socket on it?
jmon is offline   Reply With Quote
Old 08-26-2013, 08:32 AM   #5
Be sure the valve is in the "on" position. If it is turned off, the washer being pressed against the stem can make things bind up.
ask tom is offline   Reply With Quote
Old 08-26-2013, 08:48 AM   #6
PoleCat's Avatar
Rewards Points: 1,652
Lime Away will be more effective than penetrating oil.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-27-2013, 10:50 AM   #7
Thanks everyone. Ended up just taking the dremmel to it
The Following User Says Thank You to turbo91 For This Useful Post:
jmon (08-27-2013)
Shower valve replacement Jay2013 Plumbing 10 06-17-2013 04:44 PM
Best PEX tubing size for shower valve? Studly Plumbing 4 05-22-2013 06:53 PM
Shower valve for rainshower head Liv Plumbing 0 03-29-2012 10:41 AM
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 06:21 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 10:11 AM
