Shower Valve Stem - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2012, 09:28 AM   #1
Shower Valve Stem
How do you remove valve stem after nut broke off from over tightening?
cashray is offline   Reply With Quote
Old 11-24-2012, 09:35 AM   #2
Rewards Points: 13,300
Make, model, picture?
There's dozens of differant styles without some info hard to tell you how to fix it.
Old 11-24-2012, 12:23 PM   #3
It's Gerber I believe. Hot side of a bathtub faucet. I had finished replacing the rubber washer and was re-installing the stem. After turning water supply back on, there was a drip forming where nut meets valve body and I twisted the nut off trying to tighten. The threads remain in the valve body keeping the washer end of the stem from coming out. I would like to remove the threaded end of the nut so I can replace with a new one or the entire stem assembly.
Shower valve for rainshower head Liv Plumbing 0 03-29-2012 11:41 AM
Shower valve stem extension? markd5469 Plumbing 1 07-05-2010 07:48 PM
Pex shower rough in valve, what goes to the shower section? twilightcall Plumbing 23 08-09-2009 07:37 PM
Replace a shower valve with no access panel ALfromSTL Plumbing 11 12-12-2008 09:56 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
