-   -   Shower Valve Stem (http://www.diychatroom.com/f7/shower-valve-stem-164512/)
cashray 11-24-2012 08:28 AM
Shower Valve Stem
How do you remove valve stem after nut broke off from over tightening?
joecaption 11-24-2012 08:35 AM
Make, model, picture?
There's dozens of differant styles without some info hard to tell you how to fix it.
cashray 11-24-2012 11:23 AM
It's Gerber I believe. Hot side of a bathtub faucet. I had finished replacing the rubber washer and was re-installing the stem. After turning water supply back on, there was a drip forming where nut meets valve body and I twisted the nut off trying to tighten. The threads remain in the valve body keeping the washer end of the stem from coming out. I would like to remove the threaded end of the nut so I can replace with a new one or the entire stem assembly.
