Shower Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2009, 07:00 PM   #1
shower valve replacement
I've replaced the shower valves and diverter. The faucet still has a leak. What do I do?
bigdaddypalmer is offline   Reply With Quote
Old 12-31-2009, 06:08 AM   #2
Did you replace the washer seats in the valve body?? They often corrode and will leak even with new washers.
Old 12-31-2009, 08:53 AM   #3
Rewards Points: 1,578
You say "the faucet still leaks". Since this is a shower, do you mean water drips from the shower head or from the tub spout when wter is turned off? Or do you mean water comes out the tub spout when the diverter is engaged?
bob22 is offline   Reply With Quote
Old 01-01-2010, 07:35 PM   #4
Ive installed new valves in the hot and cold sides. also installed a new valve in the diverter, but there is still water leaking from the tubfaucet or shower depending witch way i leave the diverter. Should I maybe add washers? even though the new valves came assembled with them. I was going to replace everything (the whole unit) but could not find the same"set up" from any of the major home repair stores.
Old 01-02-2010, 10:06 AM   #5
It sounds to me like what you did was replace the stems and didn't replace the brass seats inside the body and thats your problem. what brand is it?
plumber Jim is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 10:11 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Shower Diverter Valve replacement twildey Plumbing 10 12-18-2008 09:43 AM
