Shower Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2013, 12:41 PM   #1
Shower valve replacement
I'm re-tiling the bathroom shower and am unsure if I should replace the shower valve and connection pipes. The house is about 15 years old. I ran a test and was unable to find any leaks near the valve, shower head, or the connection pipes. I have noticed a green substance on the pipes, and am not sure if that's a bad sign or not. Plumber fee's are $250 to replace the valve and connection pipes. Shower valve and fixtures are not included. I have copper pipes and everything seems to be soldered. Any thoughts?
Jay2013 is offline   Reply With Quote
Old 06-16-2013, 03:12 PM   #2
Rewards Points: 1,684
What brand name is the shower valve?
Old 06-16-2013, 03:38 PM   #3
The valve that I have installed now doesn't have a name on the valve. The trim doesn't either, but I've seen the trim at Home Depot. I did notice that the valve has the words "Mixet Patd" stamped on it. I've attached a picture of the setup. The soldered areas appear in okay condition, but that green stuff worries me. As noted earlier, I didn't see any leaks. How long do soldered copper pipes usually last before rupturing?
Old 06-16-2013, 05:42 PM   #4
Rewards Points: 12,808
Looks like it's been leaking from cold soldered joints.
Old 06-16-2013, 05:55 PM   #5
DIY Enthusiast
sublime2's Avatar
Replace the shower value and cut out the copper. Replace the cooper with sharkbites and new cooper or pex.
Either way it will be much less then the $250.
sublime2 is offline   Reply With Quote
Old 06-16-2013, 06:09 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 348
Solder joints can last longer than you- or it can let go tomorrow.
The green is from poor craftsmanship at the install- the plumber used too much flux and allowed it to run down the pipe.
IMO- Replace the valve now. Get a good quality valve that you won't have to worry about again.
Old 06-16-2013, 06:47 PM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,376
E's the smart decision... now while ya got it open^^^^^^^^
MTN REMODEL LLC is offline   Reply With Quote
Old 06-16-2013, 06:49 PM   #8
Thanks all.
TheEplumber: Based on the picture, are you able to tell what type of valve I have? If I elect to have a plumber do the work, is it recommended he/she replace all the copper piping?
Old 06-16-2013, 07:44 PM   #9
Plumber
Rewards Points: 348
Thanks all.
I don't recognize the manufacture.
See the red print on the pipe? Red is color code for type "m" copper. It has the thinnest wall thickness of the 3 types of copper-K,L,M . "L" will have blue writing and is the preferred wall thickness- some areas require it.
I would remove the pipe to the floor and install L or even pex(cost saving).
Your plumber may choose to leave some of it- that is a judgment call you should discuss with him- it may affect your cost.
Sorry I couldn't help with the valve ID.
Old 06-16-2013, 08:32 PM   #10
Based on the picture, can you tell if there is a leak?
Old 06-17-2013, 05:44 PM   #11
Plumber
The valve looks like it could be a kohler.
Like others have said I would replace it
while the walls are open .
$250 to do this work is a fair price.
DidIDoThat is offline   Reply With Quote
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 03:42 PM
Best PEX tubing size for shower valve? Studly Plumbing 4 05-22-2013 07:53 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Shower Spider Valve Outlet: Elbows, Braided, ?? yogi_bear_79 Plumbing 6 11-03-2011 11:44 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
