Shower Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2011, 11:28 AM   #1
analogmusicman's Avatar
Rewards Points: 560
shower valve replacement
we're renovating our "guest bath" (we did the master bath awhile ago) part of the renovation is to replace all the chrome fixtures with "oil rubbed bronze" colored fixtures. we bought all new fixtures including the shower. now,I see that I'm going to have to replace the shower valve.( the Price Phister set came with a nice new one) my question is whether this can be replaced from the tub side or whether I'm going to have to get access behind the shower and tub. luckily,the towel closet is right behind but it looks like I'd have to cut some sheetrock. so what do you think?
tnx,
analogmusicman is offline   Reply With Quote
Old 04-13-2011, 12:37 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
amm,
The towel closet is your best avenue IMHO (easier and less expensive faucet assembly), but if you want, you also can get a new faucet with a very large estucheon plate that can be installed from the tub side (at a plumbing supply house). They come with a template to show where to cut a larger hole through your shower side.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 04-13-2011, 02:32 PM   #3
Handyman
Rewards Points: 512
I agree..always easier from the back side...diverters come in different formats and you don't know how big a hole you will need. Some you solder directly into and others you need to solder on a threaded coupler. Anyway, changing from behind gives you a chance to check for leaks.
canadaclub is offline   Reply With Quote
Old 04-13-2011, 03:07 PM   #4
Rewards Points: 560
ok, not exactly what I wanted to hear but, it's gotta be done right so my favorite tool gets another "workout": the reciprocating saw!
tnx,
Old 04-13-2011, 07:05 PM   #5
Handyman
Rewards Points: 512
lol..a match made in heaven...careful with the sawzall though..it really saws ALL
Old 04-13-2011, 08:16 PM   #6
Rewards Points: 560
yeah, would't want to cut through something vital...like ME!
Old 04-25-2011, 06:10 PM   #7
Rewards Points: 560
well,they say "a picture is worth a thousand words" so look at the pic to see what I was confronted with when I took off the shower valve cover plate. yes,the "sorry fool" who did the piping for that bathroom not only screwed up the sink faucet but also reversed the pipes for the shower: cold on left and hot on right. therefore,whoever installed the valve had to get the right pipe to the other side of the valve! not only that,but the inlets on the new valve are screw type and the old valve has solder type fittings. (not that this makes much difference)
my question is whether I can use flexible pipe (like faucets) to go from the hot/cold pipes to the valve or will I have to do a bunch of soldering of copper pipes like it is now?
tnx,
Old 04-25-2011, 06:33 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now that right there is a classic.
XXX
Old 04-25-2011, 06:36 PM   #9
Handyman
Rewards Points: 512
Lord all mighty..looks like a trailer for an Alien movie. Can you get access from behind to redo it properly? I would straighten the pipes proper and solder on new threads to eliminate all of those elbows. Most times shower plumbing is behind an adjoining closet or some such discrete area. I wonder why the installer didn't just reverse the valve?
Dave
Old 04-25-2011, 06:45 PM   #10
NACE Coating Inspector
mustangmike3789's Avatar
thats awesome
mustangmike3789 is offline   Reply With Quote
Old 04-25-2011, 07:03 PM   #11
Rewards Points: 560
yeah it's a classic! yes,fortunately,there IS a closet behind this. I'm going to pull off some wallboard so I can get access.
so what do you mean by "reverse the valve",canadaclub?
tnx,
Old 04-25-2011, 07:04 PM   #12
DIY staff
Rewards Points: 7,174
Moen and Delta mixers can be piped backward (designed for back to back showers) the cartridge is then installed to suit the water inlet and you are done.---Mike---
Old 04-25-2011, 07:08 PM   #13
Handyman
Rewards Points: 512
Mike's always awake
The Following User Says Thank You to canadaclub For This Useful Post:
oh'mike (04-25-2011)
Old 04-25-2011, 08:28 PM   #14
Rewards Points: 560
the plumber must not have known that (or maybe 30 years ago "Delta" wasn't capable of that)
anyway,this new valve is "Price-Pfister" and the instructions don't say anything about that.
tnx,
Old 04-26-2011, 04:58 AM   #15
Rewards Points: 352
before you tear out the old valve you could check with a plumbing supply warehouse to see if a new trim kit would be acceptable to your re-do. If you find one then rebuild your delta, install new trim kit, and your good to go.
plumberinlaw is offline   Reply With Quote
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Shower valve installation sydni2009 Plumbing 3 09-21-2010 05:04 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 10:05 PM
