Old 08-25-2008, 12:45 PM   #1
Shower Valve question
I have this shower valve:
I believe it has a 5/8" ID on the threaded connections. can I use 1/2" copper pipe (5/8" OD) and solder the connection instead of using a threaded connection? how far should the copper go into the valve to create a good connection?
cooper4x4 is offline   Reply With Quote
Old 08-25-2008, 03:05 PM   #2
Whatamess
It should go in at least 1/2". Make sure you take the guts out before you sweat the pipe.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-25-2008, 03:27 PM   #3
I will definately do that. just wasn't sure if it was ok to sweat copper to brass at a threaded connection.
Old 08-25-2008, 05:17 PM   #4
Send a message via AIM to Marlin
Their should be stops, a point where the copper pipe won't go in any further yet isn't touching the cartridge. That's how deep you want to go with the pipe.
Marlin is offline   Reply With Quote
Old 08-26-2008, 11:03 AM   #5
any special tips for soldering brass to copper? will a 1lb propane torch do the job or should I go with mapp gas?
Pex shower rough in valve, what goes to the shower section? twilightcall Plumbing 23 08-09-2009 07:37 PM
Do the fittings need to be sweated before being installed on shower valve? twilightcall Plumbing 5 08-25-2008 12:47 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 11:09 PM
