Shower Valve Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2012, 09:18 AM   #1
Hello All,
I'm nearly finished with a shower stall upgrade in my bathroom. I haven't changed anything to my (circa 1986) shower valve and when I used the shower for the first time last night the water didn't get hot as it use to. The other shower and all sinks still have hot water so I'm thinking the valve may be the issue. I'm not sure what kind of valve this is and whether or not it has a cartridge inside that needs to be either cleaner or replaced. Any help identifying would be greatly appreciated!
ccredsox is offline   Reply With Quote
Old 02-06-2012, 12:25 PM   #2
Another Image
Another view of the valve in question
Old 02-06-2012, 12:31 PM   #3
Rewards Points: 12,790
Anytime a bathroom is remodel with fixtures are that old it's always better to also change out that valve.
So what is it you remodeled that could have effected that valve?
Newer valves have a set screw that allows you to adjust the anti scald valve. Not sure if one that old would even have one.
Every company makes there's differant so it's hard to tell you where the screw is.
Old 02-06-2012, 12:43 PM   #4
There is a screw to the left of the valve stem (the images I attached were rotate 90 degrees to the left for some reason). After some research, this valve looks to be a symmons that contains a TA-10 cartridge.
The only thing that could have been affected during the remodel is the introduction of dust/debris through the shower head neck. No plumbing was altered other than that.
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 07:21 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 05:37 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 11:11 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 11:09 PM
