#1 |
Shower valve, off/on shut off
Almost done remodeling entire bathroom and figured out that I needed to change the plumbing in order to install a new shower on/off valve. I kept the same plumbing thinking all was universal! Is this a HUGE issue? Or should i be able to fit a new valve with current plumbing?? Cement board, redgard, tub, and tile are all in!! I can easily access the plumbing through the back drywall but I rather not . Thank you all in advance and hope one of you guys can bail me out!! Thanks! I will.attach a
![]() picture!! |
#2 |
Your trying to do this backwards, should have been plumbing then the tile.
No such thing as a "universal" contorl valve there all a little differant. Everything has to be done behind that wall. If there's old steel supply lines that should have been replaced with copper, Pex or CPVC long ago. Make sure you remove the shower head before turning the new valve on. There will be trash knocked loose inside the pipes. Last edited by joecaption; 01-06-2013 at 08:38 PM. |
#3 |
call me E
If you want change the valve you'll need to access the h&c supplies- perhaps from the back. If you just want to change the cartridge you have the room for that. Turn off the water, relieve the pressure. Pull the keeper pin in the picture and then you pull out the cartridge. Install in reverse order and you're done.
But right now your tile is too tight to the valve. You've covered the trim plate screw holes.
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| The Following User Says Thank You to TheEplumber For This Useful Post: | oh'mike (01-07-2013) |
#4 |
I just use a Roto ZIp with a tile cutting bit when I find one like that.
| Display Modes | |
| How to diagnose gas valve problems | Nestor_Kelebay | How To Guides | 27 | 03-07-2013 03:17 AM |
| Can you solder within an inch of a closed shut off valve? | amodoko | Plumbing | 17 | 08-16-2012 01:29 AM |
| Shower mixing valve replacement w/galvanized pipe | rsaritzky | Plumbing | 3 | 05-13-2009 11:11 AM |
| Resource for understanding gas valve? | darsunt | HVAC | 19 | 02-04-2009 12:08 AM |
| Electrical Box near Shower Valve | dasajame | Electrical | 3 | 07-07-2008 07:46 AM |
