Shower Valve Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2011, 10:32 AM   #1
I have a shower valve that will not completely turn water off. I know next to nothing about plumbing. Can I just go buy a new valve and change it or to I have to cut pipe and reconect pipe? Can anyone help me?
kosta88 is offline   Reply With Quote
Old 08-02-2011, 12:24 PM   #2
General Contractor
You should be able to change the insides of the valve itself and fix the problem. To replace the whole valve assembly, you would need to open up the wall and disconnect/reconnect via the supply lines.
Depending on the type of valve would dictate how the cartridge or washer/seats are replaced. Some are easier to than others to work on.
Does it have a brand name on it? Can you post a picture of it?
dsconstructs is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Price-phister Shower hot side two valve O-Ring replacement? Bozohelp Plumbing 11 06-14-2011 04:44 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Replace a shower valve with no access panel ALfromSTL Plumbing 11 12-12-2008 08:56 AM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 10:05 PM
