Shower Valve Installation Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2012, 11:04 AM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 914
There is something to be said for using copper. PEX supplies no support for the valve.
BTW- can't really tell from the pictures, but if you have PEX to the tub spout- replace it. It must be copper or gal pipe. PEX is too restrictive for the tub when combined with a shower
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
oh'mike (02-29-2012), plummen (02-28-2012)
Old 02-28-2012, 01:39 PM   #17
If you mean that it's so restrictive that some of the water goes out of the showerhead when the tub spout is on, I haven't seen that problem.
mtk369 is offline   Reply With Quote
Old 02-28-2012, 03:45 PM   #18
Ron Paul 2012
I am curious if the copper pipe being held by the brackets should be wrapped to prevent electrolysis?
HandymanCA is offline   Reply With Quote
Old 02-28-2012, 08:54 PM   #19
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It happens all the time.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
ben's plumbing (02-28-2012), oh'mike (02-29-2012)
Old 02-28-2012, 08:57 PM   #20
Doing it myself
Alan's Avatar
Also :
Wow @ sharkbites on a new install
Journeyman Plumber
Old 02-29-2012, 06:05 AM   #21
DIY staff
Rewards Points: 7,174
As to the pex tub spout---it's your house,if you wish to take a chance--go ahead--fixing it correctly will only take 15 minutes --after you remove the tile---(just kidding--we get 'my shower head is dripping' questions here a lot--fix it now--)
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Shower Spider Valve Outlet: Elbows, Braided, ?? yogi_bear_79 Plumbing 6 11-03-2011 10:44 AM
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 06:21 PM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 05:03 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 01:02 PM
