Shower Valve Installation Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2012, 01:08 PM   #1
Shower valve installation problem
The single handle tub/shower valve I'm trying to install has a part that's supposed to be flush with the finished wall. The problem is that when I use a 2x4 to attach it to, the part that's supposed to be flush with the finished wall sticks really far out even when I move the 2x4 as far back as it goes. So what should I do?
The wall is made of 2x4 studs, and the shower valve goes right between two of the studs.
EDIT: note that the wall is unfinished on both sides, and the side that faces away from the tub can have furring strips added to it if needed.
mtk369 is offline   Reply With Quote
Old 02-24-2012, 01:31 PM   #2
Rewards Points: 81
Would a piece of 1x work instead of 2x? Would give you an extra 3/4" to work with.
JeepNick is offline   Reply With Quote
Old 02-24-2012, 01:32 PM   #3
Rewards Points: 13,300
You may be tring to use the plaster wall spacer. Most of the time it's not needed. It works without it right?
Old 02-24-2012, 01:36 PM   #4
A 1" thick board should work, I was just wondering whether it's considered OK to go much thinner than a 2x4.
Old 02-24-2012, 02:51 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
you'll be fine. Another approach is 2x4's above and below the valve. Use good pipe straps to anchor with - doesn't work well with pex though
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (02-24-2012)
Old 02-24-2012, 05:32 PM   #6
analogmusicman's Avatar
Rewards Points: 560
as you can see,I had to cut out a piece of stud to fit my valve in and didn't use any other bracing.
tnx,
analogmusicman is offline   Reply With Quote
Old 02-24-2012, 05:59 PM   #7
Rewards Points: 81
tnx,
Hope you reinforced that stud when you were done... Even on a non-bearing wall, I would be worried about knocking into the wall and the resulting "flex" or lack of rigidity causing problems.
Old 02-24-2012, 06:11 PM   #8
Experienced
Jackofall1's Avatar
tnx,
I think I would have either moved the stud or moved the valve, but not cut out the stud.
Mark
Old 02-24-2012, 06:15 PM   #9
You did disassemble that valve before soldering right?
Would have been far better to have used unions or pipe adapters and solder into couplings then to solder directly on the valve.
Old 02-24-2012, 06:23 PM   #10
Rewards Points: 560
where was all this advice when I did all this a year ago and posted right in this very same forum?
tnx,
The Following User Says Thank You to analogmusicman For This Useful Post:
oh'mike (02-29-2012)
Old 02-24-2012, 06:37 PM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
tnx,
We need to teach you how to control the heat a little better!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-24-2012, 07:36 PM   #12
Rewards Points: 582
what did you solder with????wow...... that should be an adjusted install....adjusted to be right
Old 02-28-2012, 11:26 AM   #13
I have another question: the valve is installed and it works, but the handle is crooked and there's no way to adjust it. Also, the valve has only two mounting holes that don't even touch the block that the valve is attached to (so a large part of the screw just hangs in the air), and it's not solid at all, so I used a few copper straps to hold it down. Since I'll need to remove all the fasteners to move it, I wanted to ask if there's a better way to mount it? I can't rely on the pipes to hold it, since they're PEX.
Old 02-28-2012, 11:44 AM   #14
plummen's Avatar
picture?
Old 02-28-2012, 11:57 AM   #15
Here are some pictures. The two black screws near the top are going through the only mounting holes on the entire valve, and it's very wobbly if only they are used.
Shower valve installation problem-dscf1025.jpg   Shower valve installation problem-dscf1026.jpg
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
Shower Spider Valve Outlet: Elbows, Braided, ?? yogi_bear_79 Plumbing 6 11-03-2011 11:44 AM
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 07:21 PM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
