Shower Valve Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2010, 08:12 AM   #1
shower valve installation
I'm in the process of installing a new tub with tile surround. I have 3 questions.
1. Should the shower valve be installed before the actual tub is installed/ set?
2. Should water resistant material be installed behind the cement backer board?
3. What do you recommend for 1/2" backer board; durock, wonder board, or hardibacker??
any advice is fully appreciated!
thanks
RMC
rcassidy is offline   Reply With Quote
Old 10-31-2010, 08:31 AM   #2
the Musigician
DangerMouse's Avatar
When I installed my new tub last month, I set the tub down first, did the drain and then set up the end walls, then the plumbing.
DM
The Following 2 Users Say Thank You to DangerMouse For This Useful Post:
braindead (11-01-2010), rcassidy (10-31-2010)
Old 10-31-2010, 08:43 AM   #3
It's usually best to have the tub in place first. Sometimes irregularities in the framing against which the tub rests can cause the actual centerline to be slightly off the stated measurements in the specs/instructions. Also, setting the tub in place can be difficult with the valve and spout stub protruding from the wall.
I'm a plumber, so I've only gotten involved in the rest of it (framing, tiling etc) once when renovating a bathroom for my mom. I used 15# roofing felt (tar paper) on the wall behind 1/2" durock, and I taped/mudded the seams in the durock before tiling. I had just read that in a DIY book, and it's worked well.
Ishmael is offline   Reply With Quote
The Following User Says Thank You to Ishmael For This Useful Post:
Old 10-31-2010, 08:55 PM   #4
thank you both, that is what I thought, and what I will do....
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Need help replacing shower diverter valve magnolia Plumbing 9 07-12-2008 09:54 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 10:09 PM
Shower installation help needed neonrider General DIY Discussions 1 08-24-2005 05:15 PM
