-   -   Shower valve installation (http://www.diychatroom.com/f7/shower-valve-installation-81964/)
sydni2009 09-21-2010 09:53 AM
My contractor has installed the new shower valve in our new tiled shower. It sticks out beyond the front of the studs as I know part of it should, but to install the cement board over/around the valve and the connections, and flush onto the studs, it would have to be knotched out in the back of the cement board to contact the studs (it is hitting the plumbing and fittings that also protrude slightly). Something isn't right, I know. Am I correct in assuming that the valve must not be installed correctly, and that if it was, the cement board should simply be cut out around the valve, and fit neatly over the plumbing and screw flush to the entire stud? My prime will be here shortly, so I want to know what I'm talking about. Thank you for any incite.
DexterII 09-21-2010 01:21 PM
Thankfully I have not had to mess with a shower valve for a while, but, as a result, I can't get a clear picture in my head. It seems to me that at least some of the valves come with a mud plate (???) that the wall board finishes against, and then the escutcheon covers everything. In other words, it may very well be correct, and regardless, you're okay, as long as you verify it before anyone gets much farther along. If the plumber can't be clear, the box with the instructions must be around there someplace, and if not that, go to the manufacturer's website, and look at the instructions. It should be esay enough to verify at that point.
sydni2009 09-21-2010 02:14 PM
I did discuss with my contractor. He said what they were going to do is satisfactory, but he did relocate the valve to satisfy my concerns. He changed from a 2x to a 1x to give the extra space to recess the valve and fitting behind the cement board instead of within the cement board. Thanks for the reply.
braindead 09-21-2010 05:04 PM
I think you should check some more, your valve should have a plaster guard with it which gives the FINISHED wall line, if the valve has been changed to be behind the cement board it may be TOO FAR IN! :huh:
