Shower Valve Install Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2012, 01:41 PM   #1
Rewards Points: 14
Shower valve install problem
Redoing the entire bathroom. My wet wall is made of 2x3s and the rest of the room is 2x4. So I need a shower valve/diverter kit that will fit in a 2x3 wall. Water is coming up directly below so no need to cut holes in the studs and venting is below as well. So 2x3s work except for necessary depth requirements for a shower valve. I've read that there are products by Moen and Delta that will fit but can't find them.
Thanks in advance.
Boomer2012 is offline   Reply With Quote
Old 06-28-2012, 03:36 PM   #2
DIY staff
Rewards Points: 7,174
Call Moen--or Delta--their customer technical help line is good---A stock Moen should work--but call and get the final word from them.---Mike---
Old 06-30-2012, 02:49 PM   #3
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
all depends on what your finish wall is it tile,seamless,fiberglass stud wall to surface =thickness
wctekkk is offline   Reply With Quote
soldering copper pipe on a shower mixing valve. Ed911 Plumbing 7 05-17-2012 09:27 AM
Am Standard Shower mixing valve problem WMS Plumbing 5 02-13-2012 09:07 AM
Moen Single Valve Shower Handle problem! F8James Plumbing 3 04-16-2011 04:32 AM
install heights for shower fixtures rtoni Plumbing 2 10-20-2010 08:49 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
