Old 05-04-2008, 03:45 PM   #1
Doneitnow
Shower Valve Destroyer ? Help!
I recently renovated my master bathroom and installed 3 new Kohler shower valves in a large shower. Anyway, the stone I installed in the shower was a ungauged sandstone that is almost 3/4" thick. The trim would not go on properly, so I order some extension kits from Kohler.
I really screwed up and took one of the screws out of the shower body and the water started leaking..I re-tightened the screw and it still was leaking. I shut the water main down and then re-tightened again with no pressure and installed the other 2 extension kits. When I turned the water back on it still leaks as if I cant turn of the valve xompletely. Anyway the questions is "Is there any way to fix this or do I have to reinstall another valve?"
doneitnow is offline   Reply With Quote
Old 05-05-2008, 09:24 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Call Kohler, they will send you the needed parts and tell you how to fix it.
Not a Kohler fan myself.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 05-05-2008, 11:15 PM   #3
Doing it myself
Alan's Avatar
We aren't either. First choice is Moen all the way.
Journeyman Plumber
Pressure Balance Shower Valve Hammer glenn60 Plumbing 7 06-17-2009 09:30 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
How to change the shower valve? amdspitfire Plumbing 17 04-06-2008 10:05 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 11:09 PM
aging symmons temptrol shower valve v240969 Plumbing 1 01-01-2008 06:24 PM
