-   -   Shower Valve Destroyer ? Help! (http://www.diychatroom.com/f7/shower-valve-destroyer-help-20613/)
doneitnow 05-04-2008 03:45 PM
:laughing:I recently renovated my master bathroom and installed 3 new Kohler shower valves in a large shower. Anyway, the stone I installed in the shower was a ungauged sandstone that is almost 3/4" thick. The trim would not go on properly, so I order some extension kits from Kohler.
I really screwed up and took one of the screws out of the shower body and the water started leaking..I re-tightened the screw and it still was leaking. I shut the water main down and then re-tightened again with no pressure and installed the other 2 extension kits. When I turned the water back on it still leaks as if I cant turn of the valve xompletely. Anyway the questions is "Is there any way to fix this or do I have to reinstall another valve?"
Ron The Plumber 05-05-2008 09:24 PM
Call Kohler, they will send you the needed parts and tell you how to fix it.
Not a Kohler fan myself.
Alan 05-05-2008 11:15 PM
We aren't either. First choice is Moen all the way. :thumbup:
