Shower Valve With 4 Copper Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2015, 01:13 PM   #1
Rewards Points: 8
shower valve with 4 copper lines
I gained access to the shower valve and found it had 4 1/2" copper lines rather than 3. My replacement valve has 3 and confused about what the 4th one is for
tfsboroga is offline   Reply With Quote
Old 12-24-2015, 01:16 PM   #2
Rewards Points: 1,950
Picture please and how many water outlets does your shower have?
Old 12-24-2015, 01:27 PM   #3
griz's Avatar
Rewards Points: 570
Hot, cold, shower & tub spout.
griz is offline   Reply With Quote
Old 12-24-2015, 03:33 PM   #4
Rewards Points: 8
finally found a site that identified the bottom line as the tub spout which there is none. Assuming purchased in a contractor pack and "roughed" the copper into the valve prior to installation in the wall and used a shower/tub valve for a shower only installation
thank you Griz
Old 12-24-2015, 03:42 PM   #5
Rewards Points: 8
someone at home depot suggested sheetrock as a good flame protection while sweating the lines back into the wall; said the paper will burn away but the gypsum works great as flame protection. Is this a true statement?
Old 12-24-2015, 03:46 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 672
A piece of sheetmetal works better- or a soldering blanket
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (12-24-2015)
Old 12-24-2015, 03:46 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
Yep......just peel the paper off one side.
Old 12-24-2015, 04:35 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
thank you Griz
Very common, just put a plug in the bottom post.
Coastal South Carolina
Old 12-24-2015, 06:32 PM   #9
I would suggest a squirt bottle full of water wet the burnables prior to starting.
Shower Valve Assembly/Locking Nut rookie49 Plumbing 11 01-10-2013 11:14 AM
Compression Valve for leaky pipe (not copper)? DIYsoon2Bpro Plumbing 11 01-18-2012 06:40 PM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 09:06 AM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 05:03 PM
