Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2012, 10:01 AM   #1
Rewards Points: 240
shower valve
this is what is in my new to me house. excuse the dirtyness
the problem.
the HWH puts out HOT water. but this valve only puts out warmish water.
and, the handle only turns to the straight up position.
i believe that there is some kind of limiter inside of the assembly. but idk how to get into it to see/adjust.
it says DELTA on it.
Fix'n it is offline   Reply With Quote
Old 04-06-2012, 10:44 AM   #2
Rewards Points: 14,306
Your anti scald valve may just need adjusting.
Not sure on that model but with most you remove the handle, the chrome trim
and there may just be a set screw that can be backed out a small amount to adjust it.
http://video.search.yahoo.com/search...+faucet+repair
Old 04-06-2012, 10:48 AM   #3
Rewards Points: 1,766
Go to:
http://www.deltafaucet.com/customers...html?document=
It looks like your fixture; info there explaining how to adjust the temperature limits.
bob22 is offline   Reply With Quote
Old 04-06-2012, 07:18 PM   #4
Rewards Points: 582
the problem.
little end cap pops off exposing limit setting which can be adjusted....
Old 04-08-2012, 06:50 PM   #5
Rewards Points: 240
thanx, fella's
that is not my model. i am trying to find mine.
i removed the handle, but the end cap does not budge. and i don't want to force anything.
Old 04-08-2012, 07:18 PM   #6
DIY staff
Rewards Points: 7,174
grab the chrome collar behind the handle--see of that unscrews with the handle attached---
Old 04-08-2012, 08:13 PM   #7
Rewards Points: 240
i could not get it to turn. the faucet also says "monitor" on it. google didn't give me my model.
Old 04-08-2012, 08:46 PM   #8
DIY staff
delta T 14478 LHP--I found that at 'faucets direct'--including a parts diagram---my computer is ill and not being cooperative--
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Shower Control Valve AZSun Plumbing 1 07-31-2011 11:39 AM
shower valve weirdness wombosi Plumbing 2 06-26-2010 02:59 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 04:37 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
