Shower Valve. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-15-2011, 02:12 PM   #1
shower valve.
Hey guys. My wife and I just bought our first house and about two weeks ago the push button on the shower valve that diverts water from the spout up to the shower head broke. The back side is corroded and the spring shot it out into the tub. We redid the paint and fixtures and this gave us a reason to put a new shower set in. We found a month that we like and then watched how to install it. I have two questions.
1) can I installed shut off valve in the access panel so the whole system doesn't have to be shut off if this happens again?
2) I haven't soldered copper pipe before. Is it allowable to do copper to pex to install the shower valve? What is the estate way for a diy'er?
I'm a mechanic and therefore am mechanically inclined, but just not when it's related to the house. Any help/input/suggestions would be great.
Mike
Sent from my DROIDX using DIY Chatroom
blackws6ta is offline   Reply With Quote
Old 12-15-2011, 03:04 PM   #2
Rewards Points: 582
yes you should install shut off valves.....they have compression valves and adapters to go from copper to pex.if you are a mechanic no problem for you even if not...maybe alittle tough....you can do it.....ben
Old 12-15-2011, 04:23 PM   #3
Thanks. Will the line that runs up to the shower head just come out with the assembly?
Old 12-15-2011, 07:47 PM   #4
Rewards Points: 582
no it will not has a lug ell fastened to a 2x4 to support shower arm...should be able to cut it off in access door where you are going to put valves....pictures will help...
Old 12-16-2011, 11:20 AM   #5
I didn't have a chance to get. Pictures last night. But when I looked at it prior to this. There's is a valve and it has lines coming in like a plus sign. Water Supply is on left and right shower head is up and spout is on bottom. So I am going to cut the two supplies and the one going up to the shower head correct? The lower "spout" line will come out with the valve correct? I don't know how the new ones come packaged so I think I'm having a rough time visualizing it. Then just adapt to pex and put in shutoff valves then go to shower valve and test for leaks. Thanks again in advance.
Old 12-16-2011, 02:39 PM   #6
In a little over my head
Rewards Points: 706
Soldering pipe isn't that hard. In fact I think it's kinda fun. It's a good skill to have as a mechanic, too, for when the molded heater hose you need is out of stock. Buy a good Mapp torch (yellow tank) and practice a on a few scraps and fittings.
As a new homeowner, you'll get to do it again, too.
ratherbefishing is offline   Reply With Quote
Old 12-16-2011, 04:29 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 356
Do not run pex to the tub spout. It creates too much restriction and causes your shower head to dribble.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (12-16-2011), oh'mike (12-16-2011)
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
Shower Control Valve AZSun Plumbing 1 07-31-2011 12:39 PM
shower valve weirdness wombosi Plumbing 2 06-26-2010 03:59 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 05:37 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
