Shower Value - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2012, 09:51 AM   #1
shower value
Every time toilet gets flushed or sink faucet is turned on the person in the shower gets doused with cold water. Is there a cartridge that can be added to prevent this?
edlueck is offline   Reply With Quote
Old 05-16-2012, 12:18 PM   #2
There isn't anything you can add on.The only way to prevent this is to install a new pressure balanced faucet
plumberman134 is offline   Reply With Quote
Old 05-16-2012, 12:59 PM   #3
Homerepairguy's Avatar
Rewards Points: 998
Do you mean the person in the shower gets doused with *hotter* water instead? That's what should happen if the toilet is flushed or sink faucet is turned on.
If so, you could probably alleviate the increase in shower temperature somewhat "for toilet flushes", until you install a pressure balanced valve. Try partially closing the valve that feeds water to the toilet to allow only about half the water flow to refill the toilet tank. This should reduce the amount of cold water "robbed" from the shower. The negatives of course will be that it will take twice as long to refill the toilet tank along with more water refill noise.
HRG
Homerepairguy is offline   Reply With Quote
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
