In A Shower With Two Handles - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-21-2010, 08:38 PM   #1
In a shower with two handles
what do they call the chromed sleeves that cover the long valve stems that are needed to go through the tiling?
They go between the handle and the valve body and thread into the valve body with very fine threads.
Old 07-21-2010, 09:17 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you mean the escutcheon?
Old 07-21-2010, 09:49 PM   #3
Electrician
Proby's Avatar
A tube.
Proby is offline   Reply With Quote
Old 07-21-2010, 10:00 PM   #4
Rewards Points: 292
There is a chrome sleeve that slides over the stem and screws onto the stem body. My Gerber faucets have them but I don't know the proper name for them either. The escutcheon is the face plate right?
Jim F is offline   Reply With Quote
Old 07-21-2010, 10:46 PM   #5
nap
You talking to me?
nap's Avatar
do you have an escutcheon and this unnamed trim piece or is it all one piece?
does your Gerber look anything like this? If so, take note of part #7 on the parts diagram
http://gerberonline.com/fileLib/2,3,...er%20valve.pdf
If you have a separate escutcheon and this part, the diagram calls it a sleeve.
Old 07-21-2010, 11:52 PM   #6
Owner
LateralConcepts's Avatar
Actually it is called a threaded escutcheon [ih-skuhch-uhn]. Or number 7 in the diagram is "escutcheon threaded trim".
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-21-2010, 11:54 PM   #7
nap
You talking to me?
nap's Avatar
it is still an escutcheon.
that's like saying, yep, my car has rims on it. More specifically they are cast aluminum with a polished face and an epoxy clear coat but yet, they are still rims.
Old 07-21-2010, 11:57 PM   #8
Owner
Yep, pretty much a fancy word for shiny piece that makes it look good
Lateral
(208) 818-8241
Old 07-22-2010, 12:20 PM   #9
OK, when this 'piece' cannot be removed by a strap wrench or a Visegrip, how do plumbers get the thing off?
Old 07-22-2010, 12:23 PM   #10
Owner
Plumbers have strong hands
Actually if you're replacing it anyway, use a pipe wrench
Lateral
(208) 818-8241
Old 07-22-2010, 12:25 PM   #11
Handyman
Rewards Points: 512
If its plastic, break it off and replace it...if its metal you can try heating it while applying the wrench
canadaclub is offline   Reply With Quote
Old 07-22-2010, 12:49 PM   #12
Thanks.
Next time I try a pipe wrench. It may work when a Visegrip doesn't.
I guess I could have also put a hose clamp on the thing so the Visegrip wouldn't slip.
Old 07-24-2010, 10:28 PM   #13
Rewards Points: 292
Is it part 7 or 6- sliding chrome trim. Mine unscrew with a damp face cloth for leverage and I wrap it with nylon tape to keep it from seizing up. It will unscrew but you may desroy it if it's that tight. A pair of pliers or adjustable wrench on the edge of the sleeve may turn it but it will bend the hell out of it first.
Old 07-25-2010, 07:18 AM   #14
never hurts to put a little penetrating oil on and tap nicely with a hammer.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 07-25-2010, 09:24 AM   #15
As long as there's water in the pipe I'm thinking now a propane torch applied for a few seconds should loosen things up.
I get another crack at it tomorrow.
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Shower door pull handles loose RICK430 General DIY Discussions 5 03-29-2009 08:39 PM
