Shower/Tub Fixture Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2008, 05:12 PM   #1
Question
What is the going rate for shower/tub fixture replacement by a professional plumber? I was trying to change out the shower/tub fixtures myself and when we got behind the wall we noticed that the pipes were soldered to the on/off fixture. I have no clue about soldering so I called a plumber to come out and he gave me an estimate of $357 to cut the pipes midway and replace it with a different type of pipe that will allow the new fixture to be screwed on.
In addition, I live in a condo complex which means I currently do not have an individual cut off valve to the shower, so everytime I have a plumbing issue with the shower I have to cut off water supply to all the units in my building, he stated that he would also add the valve cut off to the shower. I thought that was a plus, but I spoke to a friend and was told that it was expensive. I am not sure if this is a reasonable fee and wanted to get some advise. Thanks
lgcaballero75 is offline   Reply With Quote
Old 01-01-2009, 08:11 AM   #2
Whatamess
If you post some pictures we can offer more help. Soldering is not a hard thing to do. You can purchase all the tools you need for under $50.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 01-01-2009, 08:56 PM   #3
357 is not a bad price for changing a tub and shower valve and installing new shutoff valves. I say go with plumber
schaaf is offline   Reply With Quote
Old 01-01-2009, 09:13 PM   #4
Whatamess
If you hire it done it will be easier but you will never learn how to do it. First job is install cut off then you can take your time.
Old 01-02-2009, 06:34 AM   #5
I feel that soldering, although a great thing to learn, is also something that takes practice and I am not sure I would want to practice in a condo where my mistake could cause some major problems for other homeowners. I recently had my shower stems replaced by a professional and it cost $165.00 so $357 sounds fair and safe to me.
faucetman886 is offline   Reply With Quote
Old 01-02-2009, 12:50 PM   #6
I appreciate the advise and your responses, I don't want to risk an accident. I have no knowledge and experience with soldering tools, just wanted to make sure I am not being taken advantage of. Thanks
Tub and shower fixture replacement golfer2b Plumbing 5 03-10-2008 03:06 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
shower fixture replacement question timsch75 Plumbing 4 09-04-2007 12:35 PM
Shower Fixture Replacement shapeshifter Plumbing 12 02-20-2007 07:21 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
