Old 08-12-2010, 09:55 AM   #1
Shower to tub drain
I am changing a stand up shower to a bathtub. It is raised 6" and the drain lines up fairly close, however I have the shower flange protruding about 2" above the concrete floor that needs converted to a tub drain, Are they just screw or glued onto the drain pipe? Since I have that 2" to work with I'm hopeing I dont have to break concrete but I have no clue how its conected and dont care to break anything gettin that sucker off.
derfman is offline   Reply With Quote
Old 08-12-2010, 08:04 PM   #2
Super Moderator
Shower to tub drain
Take a picture of what you have now---post it if you can---It will speak a thousand words.
Some one will give you the best method to change that to a tub---Mike---
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 12:11 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
