Shower/tub Diverter - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2017, 07:43 AM   #1
Rewards Points: 2,192
Shower/tub diverter
When the knob on faucet is pulled only about 20% of water goes to shower. Rest still comes out of faucet.
The faucet turns easily. Is there any danger of damage if I unscrew faucet (Moen) and buy another and screw it on?
I'm skeptical of things that seem easy. I worry about breaking something off inside and water leaks inside a wall.
And since water only comes out when handles are turned on I shouldn't need to turn a shutoff off, right?
(1991 why blue!)
Shower/tub diverter-image.jpg
Startingover is offline   Reply With Quote
Old 01-10-2017, 09:18 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,276
Re: Shower/tub diverter
Know the limitations of the materials.
Is there a small set screw on the underside?
The Following User Says Thank You to Windows on Wash For This Useful Post:
Startingover (01-10-2017)
Old 01-10-2017, 10:31 AM   #3
Rewards Points: 884
You don't need to pull the faucet to fix the diverter. Unscrew the diverter knob and remove the inner parts. Replace the rubber gasket and that should fix the problem.
clarenceboddick is offline   Reply With Quote
The Following User Says Thank You to clarenceboddick For This Useful Post:
Old 01-10-2017, 03:46 PM   #4
WOW, I'll check tomorrow when I back over there.
Clarence, so I unscrew the knob on top and then twist the faucet so its upside down and I should find a rubber gasket?
The other shower has a warped door and water runs out. There needs to be one decent shower.
Old 01-10-2017, 04:13 PM   #5
Rewards Points: 1,076
Start,
Call Moen and ask them for an install/troubleshooting/replacement manual/sheet for the model # you own. If anything is wrong, they usually will provide a replacement part for you at no charge. More than likely they can/will send you a link w pictures and an install/de-install-replacement steps..
Turning-off the water is not a requirement unless you start working w threaded pipes under pressure. If however, your wives clothes closet is nearby, flipping the shut-off valve may be a good idea
tstex is offline   Reply With Quote
The Following User Says Thank You to tstex For This Useful Post:
Startingover (01-11-2017)
Old 01-10-2017, 04:17 PM   #6
Rewards Points: 2,040
Moen will send you a brand new tub spout,
The Following User Says Thank You to Ghostmaker For This Useful Post:
Older American Standard Shower/Tub Shower Diverter repair kit dd44531 Plumbing 4 04-17-2014 01:42 AM
Kitchen Faucet Sprayer Does Not Work. Already Replaced Diverter. latenight Plumbing 13 08-12-2013 04:27 PM
Tub spout diverter operation question daluu Plumbing 7 02-06-2013 07:16 PM
Shower/Tub Diverter justintoo1 Plumbing 7 11-28-2012 10:32 AM
Removing the shower/tub Diverter Kathy65 Plumbing 10 12-06-2011 05:52 PM
