Old 11-17-2012, 12:17 PM   #1
Shower/Tub Diverter
Hi there,
Have the problem of the diverter still letting water flow at a very good rate out of the spout when the shower is on. Shower head also does not have full pressure
Figured it would be the diverter - so I just want to replace the thing.
Here is how the handle is setup...
Then this is what I am left with after I remove all of it...
Now, am I just able to loosen the stem valve with a stem wrench or pipe wrench..??
Never done diverters on a 3 handle setup - am I approaching it the right way?
Thanks!
justintoo1 is offline   Reply With Quote
Old 11-17-2012, 03:07 PM   #2
call me E
TheEplumber's Avatar
Shower/Tub Diverter
Use a cresent wrench on the nut. That will back out the stem. At that point you can decide if you want to rebuild it or take the whole thing to the store and match it up to a replacement.
Old 11-17-2012, 04:49 PM   #3
Plumber
Shower/Tub Diverter
You should also replace the seat.
DidIDoThat is offline   Reply With Quote
Old 11-17-2012, 05:40 PM   #4
Shower/Tub Diverter
Hi,
OK - so I can just take a crescent wrench to this nut?
I've watch a few videos on this on youtube, but none of the videos seem to match the same faucet hardware that I have.
...and which part is the seat?
Thank u!
Old 11-17-2012, 07:01 PM   #5
call me E
Shower/Tub Diverter
Yes, use a crescent wrench or one like the picture shows.
The seat is inside the valve body itself. The bib washer on the stem seats against it, thus its called a seat It may be scratch and need re placement- requires a seat wrench.
It's the furthest left (unlabeled) arrow in this image.
The Following User Says Thank You to TheEplumber For This Useful Post:
justintoo1 (11-17-2012)
Old 11-17-2012, 07:15 PM   #6
Shower/Tub Diverter
Hey!
Thanks very much. Thats a great illistration! It will come in very handy.
Old 11-20-2012, 10:27 AM   #7
Shower/Tub Diverter
Hi there,
Finally got a chance to check it out.
Came out with this...
Looks like it needs replaced.
Also I snapped a pic of my seat...
Does that look like it needs to be replaced as well? Might as well get it done while I'm there.
Is there a good way to give that a clean up?
Thanks for all the advice guys!
Old 11-28-2012, 11:32 AM   #8
Shower/Tub Diverter
Hi guys,
didn't do too much with this because of the holiday, but I finally got around to it.
Grabbed one of these kits from home depot..
Came out looking like this...I only just replaced the diverter.
Looks better than before. and No more drip from spout.
Condensation on concrete floor under basement fiberglass shower/tub insert bsande2 Building & Construction 2 01-22-2012 08:02 PM
Removing the shower/tub Diverter Kathy65 Plumbing 10 12-06-2011 06:52 PM
removing bathtub faucet diverter xconx Plumbing 6 10-10-2011 12:17 PM
Shower Diverter questions... dgates12 Plumbing 3 07-29-2010 08:15 PM
Diverter Valve Dilema Sasha2000 Plumbing 5 09-15-2008 11:14 PM
