Shower Trim Kit - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2008, 06:49 PM   #1
Shower trim kit
I purchased a Price Pfister shower trim kit. Little did i know that all trim kits are not created equal. Our old one is a delta and this one will not fit the old rough-in valve. What is involved in changing out a rough-in valve? Does it require sweating the pipes? B/C my hubby doesn't know how to do that. I saw a delta universal valve that says it could be installed without altering the plumbing behind the wall. Will that fit it? Help! I can't return this kit and it's so pretty. I got everything brass to match.
Fiestalady is offline   Reply With Quote
Old 11-23-2008, 08:37 PM   #2
skyman's Avatar
You will have to take out the old rough in valve seat, but you don't necessarily have to sweat the copper. You can cut the lines, clean them, and use "Shark Bite" coupling. It's really easy to use, just shove the 1/2" copper into it, and your set. Since you will be purchasing a new valve seat, you maybe able to find someone in Home Depot that will solder the 1/2" copper line in there for you, then just measure the difference (take-off) from the Shark Bite, and pop it right in.
Hope that helps. Sorry if it doesn't.
By the way, Moen is the best!
skyman is offline   Reply With Quote
Old 11-23-2008, 08:49 PM   #3
rough in valve
OK that sounds easy enuf, for someone. I will tell my husband and we'll see what we can do. Thanks!
Old 11-23-2008, 08:53 PM   #4
skyman's Avatar
Hey no problem. If you have any other questions about it, feel free to contact me @ ajsimon311@gmail.com.
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
Delta shower trim rjniles Plumbing 1 09-20-2007 04:14 PM
