Shower Trap Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2008, 05:32 AM   #1
Shower trap leaks
Hi guys and girls. Does anybody know how you stop a shower trap set in tiles from leaking. This is in an upstairs shower and has ruined the ceiling in the room below. I have pulled the Gib/drywall off to gain access and am letting the timbers dry. Any suggestions as to where to start? How do you get the trap our without wrecking the tiles?
Kiwi DIYER is offline   Reply With Quote
Old 08-30-2008, 05:58 AM   #2
Whatamess
Is it the drain or the trap. Sounds like you have already gained access to the plumbing. If you have to remove the drain you (if it is PVC) can break it out and replace it. If you can post some pictures.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
shower faucet Cartridge leaks Dragontat2k Plumbing 2 05-21-2008 03:16 PM
shower that leaks like a monsoon veggiechick Plumbing 4 02-19-2008 10:11 PM
leaks when shower is running but from where? bellsnj Plumbing 7 11-28-2007 10:28 AM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
