Shower / Toilet Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2010, 09:43 PM   #1
Hello all,
In the process of installing a new shower pan and toilet and I figured I'd clean up the previous owners drain plumbing mess.
Would the attached drawing be a proper location for a vent for both the shower and toilet, or does the vent need to be downstream of where the Toilet drain Wye enters the main line to the septic tank?
Thanks,
Bigmatt
Michigan
bigmatt is offline   Reply With Quote
Old 12-05-2010, 06:20 PM   #2
Rewards Points: 150
The vent is fine, it should be 2in. you can't run that trap that way, you should come into the side of the 3in. with a wye
braindead is offline   Reply With Quote
Old 12-05-2010, 07:25 PM   #3
Unfortunately, the vent is 1 1/2" all the way up through the second floor, and without tearing out a good amount of drywall the entire length can't be replaced.
What is wrong with the shower trap? All the connections will be made using a wye / 45 combo. with the connection made to the top of the main.
Bigmatt
Finishing a basement bath Vent? Pump-up toilet connection heenanp Plumbing 0 03-23-2010 07:43 PM
Is $4000 too much to replace toilet vent? watch_hill Plumbing 1 02-17-2010 01:52 PM
toilet wet vent questions (with sketch) Queso Bandit Plumbing 3 03-28-2009 08:15 PM
Do I Need A Shower Vent WGC454 Plumbing 2 11-26-2008 11:47 AM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 10:05 AM
