Shower Temperature Adjustment - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2008, 11:50 AM   #1
Shower temperature adjustment
So we've got a Moen setup in our bathroom, and the shower adjustment range is just tiny. It's more of an annoyance than anything, but I was wondering if it was "fixable"
In a nutshell, I'll describe it as if it was the hour hand on a clock...
If you have the temperature knob set at say 11:00, everything is fine. If you even NUDGE the knob to 10:59, it gets a lot hotter, and vice-versa if you bump it over to 11:01, it's a drastic swing to cooler.
I've found that doing temperature adjustments literally has me tapping the end of the handle to move the knob half a degree or so.
Any ideas?
perpetual98 is offline   Reply With Quote
Old 11-13-2008, 01:22 PM   #2
Just a guess but I think the anti-scald adjustment lever may be loose. This is located under the handle (and may also require removing the cover plate). You could also go to Moens website (Moen.com) and go to the customer service section for specifics on your unit.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Shower & Tub Temperature brneilly Plumbing 4 10-20-2008 10:12 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
