Shower Temp Changes - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2012, 12:26 PM   #1
shower temp changes
Does anyone know why a shower might be warm then go cold for no reason. I have a tankless water heater and the sink will still have hot water. I can turn the shower off and back on and the water will get warm again.
rascel is offline   Reply With Quote
Old 04-16-2012, 10:41 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Possibly a bad pressure balancing spool.
JDC is offline   Reply With Quote
Old 04-16-2012, 11:55 PM   #3
Rewards Points: 12,808
Which is inside the control valve for the shower.
If you can ID who made your valve the companys web site may have directions on how to fix it.
Old 04-17-2012, 08:11 AM   #4
Thanks maybe I willl just change valves.
Where "exactly" does the shower pan Membrane go? remodelin'girl Plumbing 1 01-16-2010 06:22 PM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-13-2009 12:21 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Plumbing in the shower head obeans Plumbing 3 03-11-2009 04:08 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
