Shower Surround Install Advice? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2013, 08:09 PM   #1
I have a Sterling Ensemble made with Vikrell. The tub is in, and I'm about to install the rear wall. The only place that the directions specify applying silicone is at the outer edges of the side walls.
Should I just stick to the directions, or would it be wise to silicone the entire tub/surround transition?
Thanks in advance.
iceclimber2001 is offline   Reply With Quote
Old 01-11-2013, 08:48 PM   #2
Rewards Points: 636
they do that so if any water gets in to seams it will seep out at tub flange. i like to use silicone at verticals when assembling then after all install seal all seams with a tight bead reason why is when in someone else's bathtub doing a repair the horizontal seam always looks bad from scum build up in seam
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 01-11-2013, 10:08 PM   #3
Thanks. So if I understand correctly:
1. Don't seal horizontals. It will accumulate scum.
2. Seal the vertical seams during and after install.
That makes sense and sounds simple enough.
Old 01-11-2013, 10:33 PM   #4
Rewards Points: 636
1 if you do not seal horizontals it will build up scum
2 seal verticals while installing
3 seal verticals and horizontals after install is complete
that is what i do
Old 01-11-2013, 10:41 PM   #5
Got it. I thought that your original comment about the scum in the seam attributed the scum to the seam having been sealed.
This is helpful. I've never done anything like this, so I'm learning as I go.
Chris
tub surround - advice needed jheavner Kitchen & Bath Remodeling 0 11-19-2012 01:52 PM
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 5 10-15-2012 03:31 PM
Using a tub surround for shower surround Sbruce Building & Construction 2 08-21-2010 08:21 AM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-13-2009 12:21 AM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 03:36 PM
