Shower Still Dripping After Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2010, 02:41 PM   #1
Question
Hi, I am new to the forum.
I recent replaced the 2 stem unit assemblies for my Delta faucet controls and it is still dripping every bit as bad.
It is a dual control fixture
The repair part I used is RP1740 and it appears to be identical to what I removed.
The only part I did not replace what the plastic control extensions.
Any help is appriciated.
Thanks!
Here is a picture of what the assembly I replaced looked like.
KilrB is offline   Reply With Quote
Old 06-06-2010, 10:25 PM   #2
Pull the stems back out and look inside you need to change the springs and seats.
SuperPlumberGuy is offline   Reply With Quote
Old 06-07-2010, 08:52 PM   #3
Thanks for the reply.
I thought there should be more to it, but when i looked inside I could not see anything else to replace.
I will give that a better look.
Fiberglass Shower Repair Mr.Pappy Building & Construction 5 03-28-2010 05:54 PM
Water dripping in the shower??? Sellncars Plumbing 4 12-05-2009 09:07 PM
shower repair phunam04 Plumbing 2 02-05-2009 12:45 AM
How Do I Repair an Improperly Installed Shower Floor MartinGale Flooring 3 11-26-2007 09:36 PM
Shower Dripping Hot Water, Should I Shut Off Emergency Oil Burner Switch? bman46 HVAC 1 10-02-2007 03:04 PM
