Shower Stem Troubles - Putty V. Tape? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2013, 10:35 AM   #1
Shower Stem troubles - Putty v. Tape?
I just finished my new shower and I have a very slow, but steady, leak at the shower stem. I installed the stem using pipe dope and let it dry for 24 hours, yet I have a drip about every ten seconds.
I used dope on the other connections without a problem, though with the angle to the stem I'm limited in how far I can turn/tighten. Would teflon tape be a better choice in this use case? Any other suggestions would be very welcome.
brendilon is offline   Reply With Quote
Old 10-15-2013, 11:39 AM   #2
Rewards Points: 14,020
Use both.
Old 10-15-2013, 01:02 PM   #3
What I've read suggests using tape but like joecaption said I'd use dope and tape and it should definitely seal it. Let us know if it still leaks.
Panda2 is offline   Reply With Quote
Old 10-15-2013, 01:17 PM   #4
Master Plumber
Benplumbing's Avatar
Pictures of the faucet would help. You shouldn't have to use tape dope or pipe dope to seal this... there are probably other o-rings, gaskets and whatnot that should be sealing the stem. Especially if its a new one
Benplumbing is offline   Reply With Quote
The Following 2 Users Say Thank You to Benplumbing For This Useful Post:
ben's plumbing (10-15-2013), plummen (10-15-2013)
Old 10-15-2013, 05:34 PM   #5
Rewards Points: 582
shut off water ...remove stem assy check for any debris clean out cup... apply alittle faucet lube to o rings and reinstall... ben sr
Old 10-15-2013, 06:37 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 818
Invest in some stem wrenches to give yourself better access- and put the pipe sealant and tape away- not needed on a stem repair
Follow ben & ben's instructions
Old 10-15-2013, 08:08 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Are you referring to a stem coming out of a 2 handle faucet,or a gooseneck coming out of the wall for shower head to install to?
If its the gooseneck to the shower head Id suggest using good sealer like rector seal on the threads before installing it.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Installing Shower Stem sweaty Plumbing 1 07-08-2011 03:45 PM
Mystery Shower Stem (Pics) bosscogg Plumbing 6 05-16-2011 08:55 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
