Shower Stem Not Turning To Turn On Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2012, 06:57 AM   #1
Unhappy
Shower stem not turning to turn on shower
I have a Moen 3 handle faucet set in my shower. Hot and cold water turn on fine. I'm having trouble turning the faucet to shower knob. It's not spinning. It just doesn't want to turn. Therefore; it won't turn on the shower. The faucet water for the tub works fine with no leaks. Any suggestions would be helpful. Thanks. Very frustrated.
herblady is offline   Reply With Quote
Old 07-08-2012, 07:42 AM   #2
DIY staff
Rewards Points: 7,174
The diverter is most likely all limed up----
You may need a new cartridge for that--I've never rebuilt one of those---If you could post a picture one of the plumbers here might be able to identify the model and give you exact instruction for disassembly cleaning and repair---Mike---
Old 07-08-2012, 09:11 AM   #3
Thank you for the reply. Is this something i can do myself?
Old 07-08-2012, 09:25 AM   #4
DIY staff
The diverters are a simple device--usually a screw driver or allen wrench to remove the handle--unscrew the bell shaped valve cover--then a Crescent wrench to remove the packing nut---the guts will then pull right out. (some need to be twisted,unscrewed, to remove)
Old 07-08-2012, 09:27 AM   #5
DIY staff
Moen has pictures of the valves on site--but you need to identify the valve first--also they have a helpful technical help line---
Old 07-08-2012, 09:34 AM   #6
I'm new to this. Not sure how to post the picture i've taken. I've installed a bathroom faucet set brgore but not sire how intense of a job this repair would entail. I'll keep trying to post the picture. I've tk
Sken the handle off and am able to see the white plastic stem. Just don't know what to do next.
Anything will help. Thanks, Connie
From Ohio
Old 07-08-2012, 09:41 AM   #7
DIY staff
Connie--I am a dummy with computed and don't know how to post pictures--someone here should be able to help---just not me!
Old 07-08-2012, 09:47 AM   #8
Renovations contractor
Bonzai's Avatar
When you post a reply if using the website version of this forum you will see a 'manage attachments' button. This lets you upload a photo. If using the mobile app version you will see a '+' sign next to the 'send' button ... Same idea.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-08-2012, 11:02 AM   #9
How to attach a photo to a post
VIPlumber is offline   Reply With Quote
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
Crazy large noise/vibration when turning on the shower in one of the bath room! Help! KUIPORNG Plumbing 6 05-25-2007 04:55 PM
