#1 |
Shower stall winterization
I have a summer cottage and it is not winterized. I was going to put a shower stall into the cottage but was told that they will crack and will not work if the cottage is not winterized. Is this correct?
#2 |
Newbie Bill
The simple answer is yes. But there are ways to solve this problem.
What will your water supply be? Where will you be draining the shower? Where is this cottage located?
Bill A DIY Noob that knows just enough to be dangerous. |
#3 |
I drain the water out of the entire cottage and do have an existing shower there which is a steel frame. The cottage is on Georgian Bay in Ontario.
#4 |
Newbie Bill
OK, I understand now. You aren't concerned about the plumbing freezing because you drain the water from the system every year.
You are wondering if the shower stall itself will crack from the freeze thaw. I don't know the answer to that, sorry.
#5 |
Last year when I was looking at shower stalls the person at the Home Depot said that the stalls are not good for non-winterized cottages. My concern is how big an issue is this?
#6 |
Some shower stalls are made of materials that get very brittle at outdoor winter temperatures.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
| Display Modes | |
| Handicapped shower stall | reelwood | Plumbing | 5 | 10-28-2009 01:35 PM |
| How to build base for a shower stall | atm | Plumbing | 13 | 05-13-2009 11:18 AM |
| shower stall with hole (cold air coming in) | mcvane | Plumbing | 1 | 02-08-2009 11:41 PM |
| Stall Shower Renovation | Rick Bruner | General Discussion | 11 | 01-20-2008 07:34 PM |
| installing lights in shower stall | mcvane | Electrical | 2 | 03-30-2007 06:34 AM |
