#1 |
newer than a newbie...
shower stall with hole (cold air coming in)
We have a shower stall in our basement washroom. We moved in about a year ago, and it was not a very 'clean' looking job.
I cleaned out all the silicone in this shower stall, and reapplied it to where I thought it was needed. I also discovered that this stall is actually not one single piece. There is a base part from the ground to about 2 feet up. Then, one side of the wall has another piece of plastic and the other side of the wall has another piece of plastic that kind of connects like a puzzle (3 pieces total, and then the glass windows/doors). Anyways, I decided to apply a few layers of silicone, to ensure that no water would seap into the cracks where the 3 pieces of this shower stall meet each other. I then, discovered that at the bottom corner of where the three pieces meet, there is a pretty large hole (you can probably fit a quarter in there), and just felt a very cold draft coming from it. Obviously, whoever put this washroom in place did not properly insulate behind it. I couldn't really put on silicone to cover this. My question is, how do I properly 'plug' this hole so at least I can prevent cold air from coming through, and then put a good layer of silicone on there, to prevent water from doing any damage. Thanks. |
#2 |
Where the shower wall kit pieces meet there is an overlap and the "joint" is already siliconed. Adding a layer of silicone over the exposed surface joint you can see after installation is redundant.
| Display Modes | |
| Ideas for shower stall walls | moneymgmt | Building & Construction | 15 | 09-01-2010 02:48 PM |
| Stall Shower Renovation | Rick Bruner | General Discussion | 11 | 01-20-2008 07:34 PM |
| installing lights in shower stall | mcvane | Electrical | 2 | 03-30-2007 06:34 AM |
| Shower stall question... | Alan | Remodeling | 1 | 05-31-2006 07:57 AM |
