Shower Spout Height - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2011, 03:51 PM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by anesthes View Post
Thanks guys. Got it all done today. Left a little slack in the pex in case I need to move the whole assembly 1/2" or so in either direction.
-- Joe
Side note : Don't use pex for the tub spout.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (12-30-2011)
Old 12-30-2011, 04:20 PM   #17
011010100110111101100101
Rewards Points: 160
Pex supplies the mixer. The riser to the shower spout, and to the tub spout are soldered copper. I used pex almost everywhere else in the house that I could.
The mixer is actually all copper, I used those pex-copper bends and soldered those on rather than a sweat fitting and then a 90. I think it was cleaner this way.
I'll snap a picture later.
I've never done a bathroom rough in before. Hopefully all will go well with the inspector this week.
Thanks again!
-- Joe
anesthes is offline   Reply With Quote
Old 12-30-2011, 08:39 PM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by ben's plumbing View Post
set shower mixing valve at 48" to center off floor....as far as tub spouts go we set mixer from tub rim to center of mixer 12-14" then drop spout 6-8" down .....some have a min off center of mixer so it don"t dribble out of shower head.....
I new there was a reason I liked Ben!
plummen is offline   Reply With Quote
Old 12-30-2011, 08:40 PM   #19
plummen's Avatar
Yeah that could get interesting when running lots of hot water!
Old 12-30-2011, 08:55 PM   #20
Rewards Points: 160
Care to explain?
-- Joe
Old 12-30-2011, 08:58 PM   #21
plummen's Avatar
Depending on it theres a gap between spout/wall if you ran enough hot water the pex might tend to soften and take a set in its new orientation once it cooled back down
Old 12-30-2011, 10:25 PM   #22
Rewards Points: 160
Oh you mean pex between the actual spout. I thought you meant between the elbow fitting the spout screws into and the mixer.
-- Joe
Old 01-05-2012, 11:39 AM   #23
Rewards Points: 160
It all passed inspection. Thanks guys.
-- Joe
Old 01-05-2012, 09:23 PM   #24
Doing it myself
Alan's Avatar
No :
What i'm referring to is the restriction that the pex fitting causes in the spout piping.
It will not allow enough water to flow out of the spout, and when you're taking a bath, your showerhead will run also.
Journeyman Plumber
Diverter Tub Spout Drips on Shower Position Koo Plumbing 3 04-20-2011 12:02 AM
Leaking Shower Diverter Spout baby12121 Plumbing 5 09-27-2009 10:43 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
