Shower Spout Height - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2011, 06:19 PM   #1
011010100110111101100101
Rewards Points: 160
shower spout height
I've been told the average height is around 72". I have a 1 pc fiberglass tub/shower assembly, and from the finished floor the whole assembly is about 72". If I stick the spout out through the fiberglass wall it will be lower, probably around 70" or so or I can move it up and come out the drywall.
What would you do?
-- Joe
anesthes is offline   Reply With Quote
Old 12-29-2011, 06:30 PM   #2
jproffer's Avatar
Rewards Points: 702
You can put it wherever you want to. My first choice would be to put it through the fiberglass, but if that wasn't low enough I wouldn't hesitate to move it up to the drywall.
Or, get one of these:
jproffer is offline   Reply With Quote
Old 12-29-2011, 06:36 PM   #3
MarginallyQualified
Rewards Points: 2,464
As the water flows downward I say shower spouts can't be set too high and from an installation standpoint I'd rather not have to cut an extra hole in the fiberglass.
Escutcheon Plates... They're a GoodThing
Old 12-29-2011, 06:48 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Move it up.
If you don't then most goosenecks will cause the spout to be even lower so move it up, no one cares.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
plummen (12-30-2011)
Old 12-29-2011, 07:03 PM   #5
Rewards Points: 582
we have always set lug ell for shower around 6'6" off floor to center of outlet
Old 12-29-2011, 07:06 PM   #6
Rewards Points: 160
Thanks guys!
What do you normally set the mixer valve to? I started roughing in my blocking for it at 42", which means a 6 foot tall person won't have to bend over to adjust the temperature.
Also, as far as the tub spout goes, is there a too high? I understand min is 6" above the tub walls.
-- Joe
Old 12-29-2011, 07:14 PM   #7
DIY staff
Rewards Points: 7,174
Your numbers sound good to me---especially if the tub is used primarily for showers.
Old 12-29-2011, 07:14 PM   #8
Rewards Points: 582
set shower mixing valve at 48" to center off floor....as far as tub spouts go we set mixer from tub rim to center of mixer 12-14" then drop spout 6-8" down .....some have a min off center of mixer so it don"t dribble out of shower head.....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 12-29-2011, 08:40 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Way too high for a tub/shower valve.
XXX
Old 12-29-2011, 09:20 PM   #10
Rewards Points: 582
48"off floor for shower.....12-14"off tub rim for tub& shower...
Old 12-29-2011, 09:31 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
....and Post #6 says this is a tub shower.
XXX
Old 12-29-2011, 09:39 PM   #12
Rewards Points: 582
yep ya right I saw roughing in blocking at 42" must of had a brain freeze...thanks..ben
oh'mike (12-29-2011)
Old 12-30-2011, 01:15 AM   #13
The normal install height for a shower head is 78", unless my client specifies something different.
VIPlumber is offline   Reply With Quote
Old 12-30-2011, 10:21 AM   #14
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I agree no extra holes in the fiberglass
Showerhead : 80" off the bottom plate
Shower valve : 42" off the bottom plate
Tub/Shower valve : 32" off the bottom plate
Tub spout : 5" off the tub rim
Journeyman Plumber
Old 12-30-2011, 03:47 PM   #15
Rewards Points: 160
Thanks guys. Got it all done today. Left a little slack in the pex in case I need to move the whole assembly 1/2" or so in either direction.
-- Joe
Diverter Tub Spout Drips on Shower Position Koo Plumbing 3 04-20-2011 12:02 AM
Leaking Shower Diverter Spout baby12121 Plumbing 5 09-27-2009 10:43 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
