Old 08-29-2007, 05:52 PM   #1
Shower Smells
House is 2 yrs old and on septic tank. Drain line has a trap and all appears normal. 85% of the time there's a odor that comes from drain opening. have snaked line and it's clear. Any ideas, we're getting tired of that nasty odor. Thanks, Paul
desron1964 is offline   Reply With Quote
Old 08-29-2007, 09:08 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Shower Smells
Is the drain properly vented?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 08-29-2007, 10:41 PM   #3
Shower Smells
P traps only work when they have water in them. Check for leaks at the P trap if you can. pour a couple of gallons down the shower drain 2-3 times a day see if this helps. if it works you might have a slow leak.
I have had a few clients with this same problem with showers they hardly use.
People forget the water in a p-trap will evaporate.
Hope this helps.
Big Bob is offline   Reply With Quote
Old 08-30-2007, 07:28 AM   #4
Send a message via AIM to Marlin
Shower Smells
That's usually what it is. An improper or clogged vent sucking the trap dry.
Marlin is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
Installing a New shower facuet... BDPNA Plumbing 8 01-18-2007 09:23 AM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 08:03 AM
