Shower And Sink Issue! - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2014, 03:23 AM   #1
Hogger
Shower and sink issue!
Hi folks!
When my wife was taking a shower the other day, I noticed that there was a burping noise coming from the kitchen sink drain. Any ideas where to start the search for issues?
DH558 is offline   Reply With Quote
Old 04-10-2014, 03:27 AM   #2
DIY staff
Rewards Points: 7,174
Sounds like the drain --past the kitchen--is starting to back up----
Tell us a little bit how the drains are in relation to each other---
is the house a single story?
Slab or basement? How old is the plumbing?
Old 04-10-2014, 03:34 AM   #3
Hogger
1) Opposite sides of the house
2) Single story
3) Basement/garage. House was built in the 60's and new shower plumbing installed last year. Also, the shower drain only runs about 4' to the "tree".
Old 04-10-2014, 04:40 AM   #4
DIY staff
Had this gurgling always happened?
If so suspect a vent issue---however,I think you have a slow main drain---that means rodding the sewer line---
Let's see what others think---lots of plumbing savy members here---
DH558 (04-10-2014)
Old 04-10-2014, 05:04 AM   #5
Hogger
I just started noticing the issue about a week ago. Fortunately, nothing has backed up. Yet... Would flushing an M80 help? Lol
Old 04-10-2014, 06:28 AM   #6
Rewards Points: 144
It could be either issue that Mike stated.To be sure ,take the garden hose up on the roof and run some water down the vent.This has worked several times for me in the past and costs nothing but a little time.
mako1 is offline   Reply With Quote
Old 04-10-2014, 06:43 AM   #7
Rewards Points: 14,312
Septic or city sewer?
Whens the last time the tank was pumped out if your on a septic system?
Old 04-10-2014, 02:54 PM   #8
Hogger
City sewer. I'm going to try a couple bottles of industrial Drano in each drain and see what happens.
Old 04-10-2014, 03:06 PM   #9
DIY staff
Skip the chemicals---you or a plumber will need to work on that drain soon---
Two reasons not to: 1--It wont work--
2---caustic chemicals mean danger to the next guy touching the pipes---if you have already dumped the stuff in the pipes---warn the plumber if you need him in the next day or two--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Javiles (04-15-2014), LateralConcepts (04-10-2014)
Old 04-10-2014, 04:18 PM   #10
Hogger
Good advice, I wasn't aware that the Drano was a huge issue with pro's.
Old 04-10-2014, 05:41 PM   #11
Rewards Points: 2,110
It actually harms the plumbers cable.
Old 04-10-2014, 05:55 PM   #12
Rewards Points: 30
NO, NO, NO!!! Thank you oh'mike for beating me to it. NO CHEMICALS!
I am always vocal about how bad chemicals in drains are because they rarely work and are extremely dangerous. The father of a friend of mine is permanently disabled by drain chemicals which had been dumped in to a floor drain. The customer told him they had not used chemicals... He was burned so badly he can barely walk anymore. All because the customer used chemicals and lied about it.
SHR Plumber is offline   Reply With Quote
The Following 4 Users Say Thank You to SHR Plumber For This Useful Post:
Arlo (04-16-2014), DH558 (04-11-2014), LateralConcepts (04-10-2014), oh'mike (04-10-2014)
Old 04-11-2014, 04:35 AM   #13
Hogger
When I get home from work, I'm gonna try a couple of pots of boiling water per a suggestion. Thoughts?
Old 04-11-2014, 12:51 PM   #14
Stupid idea move on. Unless you want to possibly damage your plastic drains.
Try calling a non rooter company that is an actually plumber and get your problem looked at and snaked.
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
DH558 (04-11-2014), Javiles (04-15-2014), SHR Plumber (04-11-2014)
Old 04-11-2014, 12:52 PM   #15
DIY staff
That is not likely to help--the blockage is down the line a ways--most likely you will dislodge enough small crud to complete the blockage---
Then you will be in need of that rodder in a hurry.
If plumbing is beyond your ability or inclination, hiring a plumber is a good idea--
I don't like to do rodding---it's rather a messy job and the big main drain rodders are dangerous if done wrong---and heavy--
Ask around neighbors,friends for a plumber that they have had good experience with.
How to vent toilet, sink and shower on vent located on different wall? luvdairish Plumbing 11 05-12-2013 02:31 PM
Can a shower share a vent w/ the sink? CoconutPete Plumbing 2 04-04-2013 10:39 AM
Normal? Clogged Toilet connected to Shower & Sink KaarenStyles Plumbing 7 09-20-2012 08:41 PM
Basement shower filling with water from upstairs sink. twags Plumbing 4 05-23-2011 03:02 PM
Removing a shower replacing with sink HuskySkull Plumbing 0 01-17-2010 12:08 PM
