Shower Shut Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2008, 03:28 PM   #1
Shower shut off
Hi
I just installed a new Kohler shower and Tub faucet with a new mixing manifold.No leaks
But my shower will not shut completely off when I am running just the tub water.The shower on/off is located on the bath faucet.Did I do some thing wrong ?
Thank you in advance for any information.
mark942 is offline   Reply With Quote
Old 04-15-2008, 09:48 PM   #2
Your pipe between your manifold and shower head is either too small or has a blockage in it.
Cajun1 is offline   Reply With Quote
Old 04-16-2008, 04:16 AM   #3
New 1/2 inch Pex. No blockage. I have put a couple of these together and have never had this happen.
Thank you for the reply.
Old 04-16-2008, 07:14 AM   #4
The water pressure in this house may be higher than in the other ones you've done. 1/2" PEX ID is smaller than 1/2" copper ID and may be creating enough restriction that its forcing excess pressure up to the head.
Gencon is offline   Reply With Quote
Old 04-16-2008, 07:44 AM   #5
Thank you Cajun1 & Gencon......................
I guess I will give copper from the manifold to the shower a try.Just made the switch from copper to Pex,like I said never had troubles before. I am running 60 pounds @ well inlet.Didn't realize Pex diameter was smaller than copper. I knew the fittings were on the small side though.Learn some thing new every day. Thank you again.
Old 04-16-2008, 02:33 PM   #6
Registered User
Termite's Avatar
I'd start somewhere a lot more simple than the pipe sizing. 1/2" pex should be just fine at that pressure and for a single showerhead/tub diverter, and shouldn't cause you any problems. I see that done all the time.
You might want to try a new diverter (faucet). The little "gate" in there might not be seating. That's how you're probably transitioning from the shower head to the diverter and vice-versa. Buy a cheap one (or take the one you have back and get a replacement), put it on, and see if you have the same problem.
Old 04-16-2008, 06:03 PM   #7
Replace the diverter seems a easier start.Guys @ the local plumbing store know me on a first name basis now............
Thank You
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Shower Dripping Hot Water, Should I Shut Off Emergency Oil Burner Switch? bman46 HVAC 1 10-02-2007 03:04 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
